I want to thank Blue Shadow for bringing this topic up (capacitance of coupling caps between preamp and amp), as it recently entered my consciousness and I was glad to see it was recently discussed.
I found the discussion here to be very useful, and particularly appreciate the comments provided by Skywatcher about “…anything between 1µF and 10µF will be fine…”, but was left somewhat uncertain if I could sub in a cap different from what the original design had. I was able to get more insight into that in a contemporary, recent thread (
https://audiokarma.org/forums/index.php?threads/audio-grade-capacitors-catharsis.907641/) (mentioned above too) that gave guidance in how to compare (and substitute) film vs. electrolytic caps used in this particular location (preamp-amp coupling). In that thread, an exchange between Binkman and leestereo on the 3rd page brought up the nugget that if an electrolytic cap is used as a coupler instead of a film cap, the electrolytic should be 10x larger capacitance than the film cap (the capacitance of the latter being what the design specifies to insure a proper roll-off frequency).
Armed with this info, I approached a 30-odd-year-old NAD 7225PE in the dining room, which I use a few hours several days a week, driving a pair of OLAs. This receiver has a 10µF/16V polar electrolytic caps in series at the inputs to the main amp. I removed and measured these the other day, and found them in questionable shape: 11.6 and 11.1 µF, 2.6% and 2.4% Vloss, and 2.8Ω and 2.2Ω ESR. I have never recapped a device other than spot replacement of failed components or, in the case of speakers, old crossover electrolytic caps, but given the above, I was interested in changing these particular caps even though the unit was performing well.
Here is the relevant part of the main-in circuit. The caps in question are C401 and C402.
I do have some 10µF/50V electrolytic handy, but they are unbranded and have higher Vloss and ESR than the originals, and therefore not appropriate for this location. Next I thought I might replace them with some 10µF Panasonic ECQ-series metallized polyester caps I also had on hand, but they were much too large to fit in the space available (without daddy-long-legs type leads). But by reviewing the info in this thread and the other thread mentioned above, it was apparent that using a 1µF metallized polyester cap from the same Panasonic series should fit the bill fine, and it would fit perfectly in the chassis as well. And I have a bunch of them.
Here is a photo with the old 10µF/16V ones and the new 1µF polys. The former are among the smallest electrolytics I have handled, undoubtedly due to the low spec on the voltage tolerance.
I installed them today and listened a bit. The NAD sounded quite good before, and they sound very good if not excellent now (only 1 hour in; clarity and low-end extension are excellent, so I didn't lose anything on the low end). My aural memory isn’t good enough to do a useful comparison before-and-after, but I’m certain I have not degraded the sound. So I am happy to confirm that replacing a 10µF polar electrolytic with a 1µF non-polar film cap, for a location where it is in series in an amp input, works well. I am also happy to not have to worry about further degradation of the original caps.
I’ll probably be looking over the schematics of some of my other older equipment to see if they are candidates for this treatment. The 1µF/250V Panasonics are only about $0.40 a pop in multiples of 10.
