frisouille
French menber
Hello everybody,
I'm back with a new amp restoration a yamaha PC-4002m. My question is about two caps on the main board (signal path) that have exotic voltage range: elna for audio 100uf/120v.
The 120v caps doesn't exist in the major audio grade caps (nichicon-elna).
Some guys suggest me to put in series or parallel to obtain the right capacitance with the right voltage.
I thinking about using two nichicon in series (220uf/80v) so it'll give me 110uf/160v.
My question is about the capacitance which is too high in front of the original rating(100uf/120v).
Is it not recommended or it'll be acceptable?
Thanks for your precious help.
