ChopperChas
So I've been getting into tape for a while. I started with R2R and then got into 8-track, before moving to cassette and then fiddling with 8 track again. Here are my musings....
Old cassette decks vary wildly in quality. Most 70s decks look cool, but a great many of them sound muffled, even if the tape path and heads are spotless. The decks with Dolby usually sound better with the Dolby turned off. That said, my Nakamichi BX-150 deck is amazing, and tapes sound nearly as good as R2R, albeit with a higher noise floor. Run the tape through a Phase Linear 1000 Auto-correlator, however, and the hiss melts away.
R2R is finicky. I've had to have two Pioneer decks repaired due to issues with the tape sliding off the pinch roller, low pinch roller tension, and brake tension issues. Nothing like that happens with cassette decks... that said, even with these mechanical issues, 4-track R2R sounds amazing. It has much the same quality as vinyl or CD, but recordings have a very different sound. Fatter in the bottom end and just warmer. Again, run through a Phase Linear 1000 auto-correlator, there is virtually no hiss at 7.5 ips.
8 Track I wanted to love. My first deck played okay, but I had a hard time adjusting out the crosstalk. Opened the deck up and found that the head is held in place by a plastic clamp, which was broken, allowing the head to cock at an angle. So, I tossed that deck (it was a cheapie), and went through two Pioneer H-R99s before I found a good one. And..... was still unimpressed. I have two brand-spanking-new tapes. I replaced the splice and foam, and they were ridiculously tight -- even though they'd been shrink wrapped when I opened them. Slit the tape and unrolled a few loops and that fixed it, but even the new tapes don't sound *great*. The auto-correlator cannot adjust out as much noise as it can with R2R or cassette, and the speed does warble on most tapes. I have a ton of great music on 8 track (thanks to my father), and I *love* the tonal characteristics of 8 track recordings... but it's quite difficult to get a tape to play reliably, and cassette quality is noticeably better. The ka-clunk never bothered me, even the hiss is okay, the real problem is just getting a tape to reliably play at a constant speed :/
Also, belts are neigh-on impossible to find :/
Charles.
Charles.
