audiodon
Addicted Member
Robert, you should have enough gain out of a 440MLA. The trick is balance. The Fisher phono stage has an upper bass hump and another hump from 11-13k. The AT may not be a good match. You might do better with a Grado or something.
If you didn't get the proper decoder ring in a cereal box as a kid with the secret handshake to get into the loyal order of water buffalo, then you might consider an outboard phono stage. If you use a digital source on the line input, you might consider running an outboard phono stage into the tape mon input.
Don
Don
