c-atle-79bay
I've finally managed to get my hands on a set of Chapman T7 speakers. These are the early versions, serial numbers 161/162 so truly early. The seller provided Kef B110's as the mid range as the original polydax were in need of being re-foamed. The manufacture indicated the B110's would be a suitable replacement. As well as replacement woofers. The one in the photo is a square back driver not certain of the manufacture. The tweeters are also Polydax and have a level adjustment that goes almost to off.The only issue I'm having thus far is one of the tweeters is not working correctly. I've check continuity from the positive and negative terminals. The negative sounds it's connected, however the positive side only sounded as I turned the level adjustment (is that a potentiometer or rheostat is that has that feeling like turning an old thermostat) at a certain spot. I also connected the tweeter directly and it had sound, but I did only very low level. After hooking it up again, no matter how much I twist and turn it, nothing. I've sprayed it a couple times with Deoxit already and will try again, but after that will have to start investigating the cross over.
One question I have and seems obvious, continuity on the positive and negative sides are fully separated, if they are not, then that's a problem right?
Below are some early photos.
