FauxHall
Starting a retirement home build, like so many others here, but I'm building in the Philippines. The basic construction here is reinforced concrete foundations, columns, and header tie beams, with tiled concrete slabs floors. Walls are plastered cement "hollow-block" filled with concrete. Metal roofs are on welded steel rafters,
We'll have high ceilings, of course, but what to make the ceilings of is the question.
They sometimes use marine plywood and sometimes stuff call Hardeflex which is a cement-fiber composite. Wood is generally avoided due to the aggressive tropical termites. Gypsum board seems rare but I could be wrong.
Sometimes they use "ceiling systems" which I take can be suspended acoustic tiles. I'd have Persian carpets on the tile floors and wall and corner acoustic treatments, along with bookshelves. There would be thermal insulation like rockwool above the ceiling too.
If I got fancy, I'd make the ceiling non-parallel to the floor to create more room nodes.
How important or helpful would acoustic ceiling material be over a more reflective, and economical, options?
