Bubbalouie
Audiophilia Maximus
I have been a big fan of Harman/Kardon components. My first audio system back in the summer of 1976 consisted of a H/K receiver (I cannot remember the model number).
Currently I own a McIntosh MA6200 solid state integrated at 75WPC, and a Jolida JD-202BRC tube integrated at 40WPC. However, I have an opportunity to own a vintage H/K integrated.
First choice is a H/K A-402 solid state integrated amp
Specifications:
Power Output: 40 watts per channel into 8Ω (stereo)
Frequency Response: 10Hz to 60kHz
Total Harmonic Distortion: 0.1%
Damping Factor: 50
Input Sensitivity: 2.2mV (MM), 125mV (line)
Signal to Noise Ratio: 69dB (MM), 77dB (line)
Dimensions: 394 x 375 x 134mm
Weight: 11kg
Year: 1976
Next choice is a H/K A230 Ballad tube integrated amp
Specifications:
Power Output: 15 watts per channel into 8Ω (stereo)
Frequency Response: 15Hz to 70kHz
Total Harmonic Distortion: 1%
Input Sensitivity: 3mV (MM), 300mV (line)
Signal to Noise Ratio: 60dB (MM), 70dB (line)
Speaker Load Impedance: 8Ω to 16Ω
Valve Complement: 1 x GZ34, 4 x EL84, 2 x ECC82, 3 x ECC83
Dimensions: 13-13/16 x 4-5/8 x 11-1/2 inches
Weight: 18lbs
Finish: Copper Escutcheon, Silver Grey Cage
Additional Information:
Specifications:
Damping Factor: 50
Weight: 11kg
Year: 1976
Specifications:
Weight: 18lbs
- Both amps have been cleaned and bad parts have been replaced.
- Both amps will come 100% functional.
- Tube integrated will include new tubes.
- Both amps will be in good condition, if not better.
- The speakers have an SPL of 90dB, shouldn't be a problem driving either one.
