GreatGazoo
Member
Hi
I just picked up this amplifier for ~45 USD. The plan was to give it to my dad for christmas, as his old Pioneer has seen better days. The unit seems to be in good condition (can't test it as my own setup consists of active monitors and my sources are digital) and due to the sellers history I trust that it works as I was told.
Only problem I noticed is the input selector (which seems to be a frequent issue with this series), as it has a tendency to jump between the imputs randomly for a second when the knob is turned. It only happens sporadically and for now the problem seems to have disappeared, after I turned the knob for a minute or two, to loosen the dirt I assume is causing the issue.
The problem is that the pots are harder to reach from the inside than I expected, any chance I could try to clean it from the front instead? Will I be able to pull off the knob(s), by pulling it away from the faceplate, on this model? I'd rather not dismantle the entire thing unless I know it is the only option. For it's age it seems pretty neat and clean in general.
Any help is appreciated. Thanks and happy holidays.
