tubeboob
I had my X707ES CD player serviced.
The laser output was tested and found to be working well within normal parameters.
The sled was cleaned and lubed and now the laser moves freely along its path with no obstructions.
Problem is now a little different than before.
Now when I put a CD into the machine a number of things may happen:
Sometimes it will play from beginning to end with no skips, no stops, just beautiful music.
Other times, it refuses to play at all.
It will always read the TOC. Then sometimes if I press play it will play the disc, and sometimes it will not.
Occasionally after reading the TOC the disc will spin backwards at a very high rate of speed. When this happens and I press play, it simply would not play. If it stops spinning backwards on its own and I press play, it will usually play the disc.
Other times the disc will stop spinning after reading the TOC. And if I press play, it will play properly.
When the disc is playing and I press stop, sometimes it will stop spinning, and other times it will spin backwards, sometimes fast and other times slowly.
When the disc is spinning very fast backwards and I press eject, the tray opens with the disc still spinning in the tray.
Other times, the tray opens with the disc not spinning.
Assuming that the laser is working properly, what other sources of these problems could there be?
The symptoms seem to be an electrical glitch, as I've never heard of a CD player spinning a CD violently backwards when "stop" is pressed.
I really love the sound of my ES piece, and I would love to get it working right.
Any tecchies out there?
Cheers
Cheers
