Thanks again for the info and compliments. I would certainly recommend this project for anyone wanting in on the Klipsch sound without having to deal with older gear. Less than $2K for this type of soundstage is unbelievable.
I am getting a bit of an upper mid shout on older and poorly recorded records. At this point I am still chalking that up to my room which is pretty loud right now.
you guys just glue the insulation/poly to the inside, or staples maybe...?
Anyone wrap the horn with that stuff too? ...couldn't hurt...?[/QUOTE
You can fix the damping material to the cabinet wall(s) any way that works for you. I you do use an adhesive just don't use so much as to saturate the damping material itself or it will not work. Spray adhesive or staples work well.
If you want to damp your horns you will need a much more substantial material than the material used to absorb internal cabinet resonances. You will get excellent results with a constrained layer damping material like Dynamat and since it has an adhesive backing it is easy to apply. This is also used to damp automotive panels such as hood trunk door and roof panels. You only need cover about 2/3's of the surface area of any given panel section to gain full results. Hope this helps Best regards Moray James.
