Crossover Components Help - UK parts
kant3r
Hello
I'm trying to fix my crossover for my Cerwin Vega Clsc15, been trying for ages now still not getting anywhere due to not being able to match the components. please could someone point me to where I can order them, I'm in the UK.
250uF 100v electrolytic capacitor
4.0mH Inductor 1%
Thanks for any help, it's been lying around for months now!
Dom
Thanks very much! I'm going to use that website and add together a 100uF and a 150uF capacitor. I'm just wiring the two in parralel aren't I both into the same points?
For the inductor, there's a whole line of different ones for 4.0mH, which one's would be right for me? The only other info I had was 1% I don't really understand the rest but I know how to replace them and put it back together.
Thanks again, you've helped me a lot, I have been searching for ages online not getting anywhere!
Dom
You choose the 4.0mH which has the same wire gauge and core diameter either ferrite or air as the original.
I presume it's out of a bass circuit so a HP71 or SP71 or SP100 or AC with a similar wire gauge will be what you're after.
:music:
Check with Madisound Speaker Component's, as they surely have everything your looking for. I've purchased lot's of stuff from them over the years. Top notch place.
IRRC the inductors do not degrade over time like capacitors. Use the old one if you can and don't worry about matching it.
