I'm shifting gears on this thread.....
Well, I started this project with the intent of building a pair of CS 3009 clones as close as possible to the originals mainly because the originals are way outside my budget. The woofers and mid bass speakers are apparently unobtainium, that and a pair of SM-115s AND a pair of SM-155s became available for an unbelievably low price....so I bought them.
Quick research here shows that my decision will be frowned upon, so to the naysayers I say save your comments if you have nothing but criticism to give. Yes, the speakers need some work. The 115s need the woofers refoamed, but they sound very good and with some damping material and recapping the crossovers can be improved upon.
The seller told me up front that the 155s seemed to be completely dead though he didn't bother to have them tested after the big buzz/pop when his wife unplugged the amp while it was on. He did hook them to another amp but got nothing. Did a continuity check and the connections read open on both speakers. Pulled the woofers for access and found both speakers had a wire disconnected at the input. Took a reading and both speakers ohmed out at 3.7 ohms. This doesn't mean that the tweeter and midrange fuses aren't blown, but it does give some hope for when I hook these up in a bit to test.
I'll have more later. In the mean time, I have a pair of EMIT R tweeters with nothing to do. Would these be an improvement over the poly cells? I understand some people think the polycells are a bit harsh even after recapping.
Open to mods and improvement suggestions that can be made to make these speakers better.
EDIT; Powered them up.....THEY LIVE !!!!!, but they need some TLC. L pads need a good flush/Deoxit cleaning.
