CS R700 speaker
ohiomike
AK Subscriber
parts such as the speaker wire terminals, is there a source for any of the speaker wire terminals? I recently picked up a pair and one spring clip on one speaker is broken and I'd like to replace it if possible.....although I figure its either not fixable or the part is unobtainium.
Anyone?
Anyone?
Why look for that part when you can just upgrade & replace with new terminals.Thats what the previous owner did with my set. He got rid of the spring loaded and upgraded to metal biding post. Here’s one example
It appears to be my only choice.
That’s actually not a bad choice! Much better speaker wire connection than the cheap spring connectors and they won’t break off, Something you have to still worry about if you keep it stock.
Had time to pull the terminal cup off. Those spring clips are just held on by a couple of small screws, maybe #4 sized screws. If I could find a couple of screw terminals with that size mounting screw it would be an easy fix without changing everything else. Tried the usual speaker parts places online but no luck......did find a couple that might work but cannot come up with the size of their screw mount, but they look larger than a #4 in the pictures.
