No, you shouldn't be using a 127v globes on a 220V supply at all!
You use globes that match your supply voltage.
Put the DBT with 220v globes (a 60watt would be fine) on the primary side of your stepdown transformer (I assume you are using a stepdown to power the amp as you state it's a 110v amp)
Maybe we interprete wrongly.
I have a amp 400W/100V recapped and want to test with DBT.
of course i have a step-down transformer from 200V to 100V/110V. for testing the amp with DBT using 110V output.
The problem is that i can lamp 60w/127V ( no higher wattage lamp) only in my country where the power supply is 220V 50Hz this means it is difficult to buy any lamp with power supply.
For an amp with 400W/100V, 150wpc is the lamp 60W/127V not very suitable.
I have read it should be with lamp 100W or higher wattage as suitable for testing the amp with above mentioned specs.
But you know that i can not get such 100W or higher wattage lamps.
So als altenative as someone writes on the net i can build the DBT with 2 lamp 60w/127V in parallel in order to get as a lamp with 100-120W for my testing purposes.
My question is therefore whether it is correct or not.
Today i have tested this amp with DBT at 110V power supply( from step-down transformer) with following results:
DBT with one lamp 60w in series with the amp: the globe glows a bit
DBT with two lamp 60w wired paralell each other but in series with the amp:
both lamps light 3-5 second then dim consideringly.
A bit longer then the relay clicks.
I have almost same results by testing other amp( with full normal function) with specs. 280w/100V as the lamp in both cases are more dimmly:
DBT with two lamp 60w wired paralell each other but in series with the amp 280w/100 :
both lamps light 3-5 second then dim consideringly. The relay can click!
So i think my recapped amp 400W/100V 150wpc may be OK or shouls i test it further with DBT with 200w lamp?
