Deciding between two entry-level amps
Which amp should I buy?
  • Option A Douk Audio EL34
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
David Politi
Hey AK!
I'm a new member here, looking forward to making some new friends.
My current setup:
  • Budget AT-120 turntable (belt, MM)
  • Schiit SS preamp
  • Klipsch RF 61 (98db sensitivity)
  • 20x20' room, no room treatment
I'm upgrading my hifi at home with a tube amplifier, and I'm looking at two similar models. They appear to be from the same company (Nobsound) and I can't figure out which one to buy. Both are EL34-based SET, around 8W output/chan @8ohms, and around $350. It appears the cost-savings has affected the transformers the most, and both models are hand-wired on scaffolding.
  • Option A Douk Audio EL34 Vacuum Tube Amplifier Class A single-ended
  • Option B Luxury Aiqin L-02 HIFI EL34
I'm looking for some insight and opinions on which one would be better for my setup (posted above) within the context of classical, noise, post-punk, and afrobeat.
David
I'd go with the one from Amazon. If for some reason you're not satisfied you can return it and they'll pay the return shipping.
Plus for a few bucks you can buy their extended warranty.
You do have recourse with an eBay purchase but it takes some effort.
You might want to complement the speakers with a subwoofer for the non classical music. The post punk and afrobeat may lack that bottom end.
Hey AK!
My current setup:
  • Schiit SS preamp
David
I am fairly certain they come out of the same factory. I would choose the one by Amazon because of customer service and the extra driver tube.
