Wotcher need is an audiophile grade transformer on the pole outside. <G>
I also ran a dedicated circuit all the way behind the primary fuse panel. Yes ... I said fuse panel. Not necessarily because I was all that gung ho about isolating an audio hookup - mostly because I didn't trust what I had to feed the beast. My old country house is still running the original 60 amp service box. Works perfectly well for what it does, and I found a trick long time ago where you add a motor control box directly to the main buss bar for the house. That motor box uses two screw in fuses and you can break that down into two separate new circuits. If I add up all the extra boxes, I'm around 200 amps. You won't get a real electrician to do that, and it probably helps that I don't plan on ever trying to sell the house. I have a feeling certain code issues may have been violated in the process ...
Also ran a separate ground field for that box - not sure if I accomplished anything other than getting some nice exercise pounding a bunch of copper rods into the earth.
Speaking of lightning ... was sitting out on the front porch a couple years back watching Ma Nature getting ready to have a good go at us and <CRACK!!> the transformer that feeds my house took a direct hit that blew it right off the pole. Don't know which was scarier - the strike or the thud as it hit the ground 10 feet away. Fortunately, the power company had talked me into installing a "whole house protector" that slips in behind the meter head. Couple hundred bux, but it saved all the electronics, so money well spent.
Power strips - do try running the receiver directly to an outlet, and if that works, you can upgrade your power strip. I use a couple Eaton industrial grade outlet boxes that do the surge protection and all - certainly not the best, but a big step above the average junk strips they sell at the local big box store.
Special ordered them at the local hardware.
PS ... here's what they're feeding ... which may help explain why power is a real issue for me ...
I got a Kill-A-Watt meter a bit back. Someday when I'm feeling brave I'm gonna have to check just how much juice that sucker's dragging out of the wall when it's hittin' it ... which I'm happy to say, it does on a regular basis.
