I am working on reviving a middle aged amp (it's 22), I am trying to do this more as a chance to work on something newer than what I am used to. The owner of it has given up after a few short lived failures in the amplifier, but I want to finish it. It appears that the bad channel has had a lot of work done on it by a TV repair guy (no offense - it actually was a TV guy). The outputs have been replaced by NTE EGC36/37 replacements on the bad side. The negative driver label wiped off when I went over it with a paper towel with some solvent on it. I found some problems in the preamp for that same channel which I have addressed - I suspect they were contributing to the repeated left channel amp failure - as well as replacement parts that probably were not up to driving the 4 ohm speakers that were being used in the manner of the originals.
It is an Onkyo Integra integrated amplifier that seems to have been designed with a goal of pretty good sound quality - I would like to revive it without going crazy - and I am having a hard time finding a number of parts that match the original spec.
Anyway - onto the question of this post - in the output stage it has 2 pairs of outputs per channel (Sanken 2sa1186/2sc2837) being driven by +/- 57 volts. Each output has a .47 ohm 2 watt metal plate resistor as the emitter resistor. One of these has opened up corrosponding to it's output transistor (a non original part) which apparently shorted.
I am not having any luck finding this type of this resistor in the form factor of the original. If I replaced all the emittter resistors with identical metal film resistors of the .47ohm 2 watt variety would it likely be fine? Since this is directly in the audio path, I don't want to make a mistake here.
The original part is an MPC78 which is listed as a Metal Plate resistor which is a "low distortion factor product for acoustic products." It also says it can handle 10x it's rated power for 5 seconds and has a 10% tolerance.
It seems that if the ratings are the same it should function the same, but at the same time it seems that a metal film may not behave the same under load as a flat ribbon of metal that the original design called for. And the original is specified as a "low distortion. . ."
Seems like usually amps have cemented wire wound resistors, but I am a little worried about putting antennas/inductors in this spot unless it is ok.
Thanks!
Thanks!
