mstewart
Hello, a while ago I purchased a SX-850 that had a scratched up dial scale. Luckily I was able to find a replacement in great condition. One of the things I noticed when Installing the replacement dial scale is the bottom area where the dial pointer sits is shorter. So instead of the whole bottom of the dial pointer being supported it is teetering on the edge. As a result dial pointer wants to fall forward. Has anyone seen this? Do I need a different dial pointer to match the dial scale? Did I end up with the wrong dial scale?I can provide photos if it would help. Thank you
