Diode Substitute?
Jaman87
AK Subscriber
All-
I am working on a Technics Equalizer model SH 8046. The power supply looks fried. There are 2 Zener diodes and some capacitors that are sitting on a heavily discolored patch on the board. See
below:
The shadows on the blue capacitors are actually soot.
Here is the back of the case.
Supposedly this equalizer was sitting on the shelf with the power button off. When it was turned on it was dead. He said he had it on a surge suppressor. So not sure what the cause was. I know that even with the power switch off on the unit, the transformer has power on it. Perhaps one of the power supply components simply failed open and caused the damage. I am pretty sure multiple components are affected. I have an ESR meter and will test the caps in-situ. I have been identifying the components and making a list of what needs to be replaced, an searching the regular sources.
The diodes (Panasonic) are obsolete. I find that I might be able to replace with with NOS, but I don't want to pay what could be collector prices. And if it is NOS, how good will they be? If I go to the usual sources, I will have to find a substitute. I'm assuming these are Zener diodes. If they are then I think I have found the datasheet them
The part number for the diodes is MAZ2150. Now the service manual calls out MA2150B, but I am pretty sure these are the same. Now for some questions:
  1. Can I test the diodes in-situ or do they have to come out to test them?
  2. What are the general principles for diode substitution?
  3. I think I have found a substitute. https://ww1.microchip.com/downloads...Documents/DataSheets/1N4728AG_1N4764AG_e3.pdf
  4. I think its a toss-up between 1N4744A and the1N4743A. Can anyone advise me here?
Sorry for the long post. Thank you in advance.
John
44 is a 15v zener, 43 is a 13v zener
The data MA2 data sheet states 13.8min to 15.1 max-split the difference and put in a 14v 1w zener, ideally 2%
guessing you dont have a circuit?
what does the power supply power is it a bunch of IC's, and if so which ones?
Padlock 12-
A lot of glass zener diodes are being replaced with surface mount components. The equalizer is circa 1987. So yes, the power supply is driving some custom ICs. But if these are fried, then the unit is junk.
it's one of those units where power switch is after the transformer so yes, power will be on the secondaries when it is switched off.
check those DC voltages in orange before assuming that zener diodes need replaced.
remote repair is not my forte but i can at least point you in the right direction.
Painttoad-
Thank you for your reply. The board is out of the unit, so I can’t power it right now. Disassembly was a bear so o don’t want to put it back in and take it out again to fix it if it is broken. Besides their won’t be any voltages because the power supply is toast.
I see more than 50 components on the power supply schematic posted above. Put the power switch to OFF and connect the 120VAC line to the primary side of the power transformer. Measure and compare the voltages (AC and DC) in every places that are visible on that schematic. If you don't want to do that, you don't know where your are going.
The dark coloration near the Zener diodes is normal. They run hot in every circuit.
Painttoad-
I see a power supply that has run for some time, perhaps in a dirty environment. What I do *NOT* see is any outright sign of being "toast". . . . It may just run warm, or the caps are getting leaky pulling excessive current. (C5 would be a good example of this . . . it would take load *OFF* the zener, but possibly pull the supply close to zero output across R1 and R2.)
Oh, and in this type of application, any zener with the right voltage and an equal or higher wattage rating will be fine.
All-
Well it wasn't tomorrow, but I finally had a chance to get back to it. First off, I think there is a lot of evidence that some component gave up the ghost. Here is a photo of the inside of the cover.
Plenty of soot. Where there is soot, there is usually combustion.
Before I did any more work I used an ESR meteor to look at some of the capacitors
Out of this list, only C-19 looks good.
Then I measured voltage that were pointed out to me on the schematic by Painttoad. These voltages are mainly around the diodes on the board. I have indicated where I measured these.
Voltages measured at at D14 looks a little high but maybe okay? The cathode side of D11 looks too high. The anode voltage on D10 looks okay. but the cathode side looks like the magnitude is about right but it seems to be the wrong charge. The D12 anode voltage looks right. The voltage on the D1 anode is the wrong charge. Finally, the voltage on the positive terminal of C15 looks about right.
Comments?
John
Your voltages are good if you consider that the circuit has no load, with the exception of the anode side of D1. The schematic does not show -23VDC at the cathode side of D10.
Measure the voltages at the cathode side of D2 and anode side of D3
Do you have 4VAC between terminals 3 and 5 of the power transformer? So far, your power transformer looks good.
Ecluser-
I didn’t notice that there was no connection node on the cathode of D10. The D11 cathode voltage seems way off. I’ll make those measurements. I haven’t looked at the taps on the transformer as of yet.
I think you made an error of measurement on D11 cathode. Don't worry about that. The voltages on the Zener diodes are more useful. If the voltages are good on D2 and D3 (should be close to 15.4V according to other parts of the schematic), turn the power switch to ON and measure the voltages on D3 and D4. Should be 7.6V
The 4VAC voltage on the transformer is for the display.
Ecluser-
The Tap 3 & 5 Δ is 3.89 VAC. So the transformer is good. That's a relief.
D2 cathode is 15.0 VDC and D3 anode is 15.1VDC.
D4 cathode = 7.6 VDC. D4 cathode and D3 Anode Δ = 22.6 VDC. D4 cathode and D3 cathode Δ = 7.6 VDC
I re-measured D11 cathode. I got 32 VDC.
Thank you for this help.
Since there is no load on the power supply with the power switch to OFF, it is normal that your voltages are a little high.
When you say that D3 anode is 15.1VDC, I presume you mean -15.1VDC. Pay attention to the polarity. It is important. It looks to me that your Zener diodes D2, D3 are good. Zener diode D4 is good too.
D5 anode voltage please, with power switch to ON.
I am curious to know the voltage at D27 anode when the power switch is OFF. It will be positive, a few volts possibly. Q1 and Q2 are part of the muting-time delay circuit. If Q2 is defective, Q1 will be ON all the time and you will have no sound because the muting circuit will be active all the time.
So far, all the voltages you measured tend to prove that the power supply is good.
Apparently I made a mistake with D1 anode and D11 cathode. I will repost the revised voltage table below with the new and corrected values.
The only thing that looks out of place now is D27. Perhaps something is up with Q1?
John
Well, I see aproblem with Q1,Q2. My understanding of this part of the circuit is that when the power switch is OFF, the base of Q2 is shorted to ground by pole 6 of S1. So, Q2 should be off. As you can see, there should be a high positive voltage at the emitter of Q1, from D1 and R14. Q1 should conduct and there should be a positive voltage at the collector of Q1, of the order of +1.2VDC. The voltage should be close to +1.2VDC because there are three NPN transistors (Q4, Q5 and Q10), with their emitters connected to ground, after D27. Q1 drives the base of those transistors to mute the audio signal ehrn the collector of Q1 is positive.
We know that you have +24V at D10 cathode. Confirm that you have 0V at the base of Q2 (cathode of D9 is probably easier to reach) when the power switch is OFF, and high positive voltage at the collector of Q2 and emitter of Q1. You might need to clean the power switch to make sure there is a good contact to ground on pole 6 of S1. If you have a high positive voltage at the emitter of Q1 and a negative voltage at the collector of Q1, that means Q1 is defective.
I won't put these values in a table.
Q1 emitter sw off = 0.68 VDC
Q1 collector sw off = -15.7 VDC
Q2 base sw off = 0.69 VDC
Q2 collector sw off = 0.068 VDC
So it looks like Q1 bad. The schematic indicates 0.7 VDC at the base of Q2. Q2 emitter is 0 VDC and the collector has a low voltage (0.068VDC ) So Q2 looks off. I think this means its working. Unfortunately, I can't get into SW1. There are no holes to spray in contact cleaner / lube. I have drilled little holes on some of my receiver for this but I don't want to do it to this one as it doesn't belong to me.
Regards-
John Cyg
The voltage values on the schematic are with the power switch in the ON position. Something is wrong in your measurements because Q1 emitter is connected to Q2 collector, so the first and fourth measurements should be identical. It looks like there is a bad ground connection at pole 6 of the power switch because Q2 base should be at 0V when the power switch is OFF. You must fix this bad ground connection first.
