ashok
Hi everyone,
There have been a number of threads on AK and other places on balanced power conditioners, and the benefits they can bring in reducing the noise floor in an A/V setup. So, I started building one and wanted to share some of the details. It is not complete yet, but I will wire it all up hopefully over the next couple of weeks.
What can balanced power do for you? It can be a little, a lot or nothing at all. It depends on how clean the ac input is to begin with. A good isolation transformer can bring much of the same benefits that a balanced power conditioner can bring – namely, reduction in the common mode noise that might be riding on the power lines. But I suppose a balanced power conditioner can be used to extract the last bit of performance from your system.
In any case, I decided to build one for myself.
Guidelines for balanced or technical power systems have been part of the US National Electric Code for a number of years now. So, if implemented according to code, it can be said that balanced power systems are indeed safe. But there are some important points to note:
For more on the text of the code, please look here: http://www.equitech.com/support/647.html. The link is from Equi-tech’s website. The code also addresses proper grounding techniques, and proper overload protection.
Here is a schematic of the conditioner I am building:
It is based on the Cheapskate Unit with a few modifications – notably, fuses on both legs of the secondary of the transformer and a double-pole switch. Some things to note are:
The unit will be built in a 16” x 12” x 3” Par Metal chassis. Here is a picture of the back of the unit with all the drilling and filing completed. Warning: my metal working skills are rudimentary, and even that is being very generous. It took me about 3 hours, with the bulk of the time being taken by the IEC socket cutout. Luckily aluminum is not so hard to file.
I will post more details, and pictures of the completed unit.
Ashok
Disclaimer: I am not an electrician, just a hobbyist. You are dealing with high voltages that can kill, so please be careful. My balanced power conditioner is not UL/CSA approved, nor will it meet any residential electrical codes. If you decide to build it, it is at your own risk.
- Balanced power systems are not meant for residential dwellings.
- A trained technical person must be supervising the installation at all times.
- Switchboards and outlets supplied by balanced power must be properly identified and marked.
- The transformer does not have an electrostatic shield. It is probably preferable to have one.
- The ground on the balanced power side is tied to the incoming safety earth on the primary side. To meet the code, one would need to run a separate ground wire on the balanced power side to the grounding rod for that facility. This was of course infeasible for me.
- Each leg of the balanced power side is fused. This is OK, but I would rather have a double-pole breaker in there, with independent overload sensing on each pole, and common trip. Thus, either pole on the balanced power side can trip on its own, and also open the other pole simultaneously. With separate fuses, we do not get that feature. According to code, such breakers must be used in a technical power installation.
Ashok
