pradigmshift
I just finished my DIY PVC/Arcylic platter and mat. It is for a Philips AF-977. I have no experience with tt's but am curious as to what your views are.
Here's what I've done:
- Scrape lables of 5 records (that you don't need!) and put them on top of each other. Check that you will get right VTA.
- Glue the middle 3 records on each other using PVC glue. Before attaching, put some acrylic glue in the lable area to fill the label gap.
- Top record: first apply a layer of PVC glue to flatten out the groove area, then add a thick layer of acrylic glue (elastic kit) using a business card. Keep the lable area free.
- The top record should then be glued with PVC glue to the 3 middle records and the bottom one should be glued with acrylic glue to that. However, since I'm testing I used double-sided adhesive for this.
Usage: the played record will be well supported by the acrylic glue. When the top record is also glued the needle 'feels' five records, not one.
Impressions: I don't have much to compare instead of the orig. alu platter + rubber mat. It does sounds much more natural and more like the same songs on CD. Compared to CD it has a tad stronger mid and a litte less highs/overtones.
Question: Did you try something similar and what were your results?
Credits: http://members.home.nl/fmunniksma/Philips777.htm for ideas
