The stuff which came off the plate at 6:22 of the video is what I encountered inside my generator carburetor, a lot of it! Thankfully there was no corrosion.There's a Project Farm video about this!
Not in my vehicles because they get driven often, but I started running ethanol free in my mowers earlier this Spring and they run much better because of it.I have a pleasure vehicle that is only driven approx. 2500mi. annually. I used to run premium in it which isn't required but I felt I should put the best gas I could in it seeing gas would sit for awhile. I've recently started using Ethanol free instead due to no moisture buildup overtime. its only about 25 cents more per gallon and I only have a 10 gal tank....
Anyone think I'm foolish for doing so????
I knew Gas/Petrol had a 'life' - in other words goes bad and progressively worse after maybe a year or more, but I didn't know the newer formulations went bad as well. I get the impression you are talking in months, rather than years for this to happen.as far as i know over here only 1 company sells real petrol these days and it is very costly . a place i do work for is an agent for it . yjat stuff can be left a couple of years and still be good unlike this e5 e10 whatever along with modern diesel that lasts 3 months .
saying that i haven't tried it as of yet . e5 super seems to be not too bad if not left too long .
No, you are probably pretty smart, especially if it's only $0.25/gal more.I have a pleasure vehicle that is only driven approx. 2500mi. annually. I used to run premium in it which isn't required but I felt I should put the best gas I could in it seeing gas would sit for awhile. I've recently started using Ethanol free instead due to no moisture buildup overtime. its only about 25 cents more per gallon and I only have a 10 gal tank....
I think you’re doing exactly what you should. Engines that are used rarely and have fuel in the tanks will have the gas absorb water. Non ethanol gas is much more resistant to that.I have a pleasure vehicle that is only driven approx. 2500mi. annually. I used to run premium in it which isn't required but I felt I should put the best gas I could in it seeing gas would sit for awhile. I've recently started using Ethanol free instead due to no moisture buildup overtime. its only about 25 cents more per gallon and I only have a 10 gal tank....
Ethanol otoh, can scavenge moisture from the fuel system to be expelled with the exhaust. Occasionally alternating the two types makes sense to me.I think you’re doing exactly what you should. Engines that are used rarely and have fuel in the tanks will have the gas absorb water. Non ethanol gas is much more resistant to that.
I know. Cost me a lot in repairs to my boat engine till I switched to non ethanol gas.
Best of luck!
In the early '70's, I work at a bulk chemical distribution company (solvents, lacquer thinners, etc.). We would often add a gallon, or so, of methanol to our tanks, just for that reason.Ethanol otoh, can scavenge moisture from the fuel system to be expelled with the exhaust. Occasionally alternating the two types makes sense to me.
here is an article about diesel https://www.iims.org.uk/sticky-dies...efzJbzfg-ugqM6ylBKAoxtlIHLdAadCyKGjm7xqpJWIl8I knew Gas/Petrol had a 'life' - in other words goes bad and progressively worse after maybe a year or more, but I didn't know the newer formulations went bad as well. I get the impression you are talking in months, rather than years for this to happen.
This reminds me when I could buy 5 Star Petrol, (in the UK) one of my cars responded very well to a tankful.![]()
Fuel stabilizer doesn't always do such a good job per the video @davidhun provided.If you're really worried about it, just use a fuel stabilizer, especially if your engine isn't used for weeks or months at a time.
How to Remove Ethanol from Gasoline (from sciencing.com):
I don't think you're foolish. It's your business. Why would I care?I have a pleasure vehicle that is only driven approx. 2500mi. annually. I used to run premium in it which isn't required but I felt I should put the best gas I could in it seeing gas would sit for awhile. I've recently started using Ethanol free instead due to no moisture buildup overtime. its only about 25 cents more per gallon and I only have a 10 gal tank....
