jetblack
Resistors & transistors/tubes are affected by temp changes. The larger the resistor value, the bigger change in ohms with temp change (40 deg F change will change a 100 ohm resistor by 2 ohms, change a 10k ohm resistor by 200 ohms, a 10M ohm resistor by 200k ohms). Currents & required voltages for transistors change with temp changes. I would need to do some digging to find out if cap or inductor values are affected.
