Interesting Retro -- So the 100,000 hour rating so often seen for SS devices must be akin to the expiration date on Twinkies -- put there to satisfy some bureaucrat's job description, but actually will last forever when handled properly.........
To clarify I did not address the entirety of solid-state devices in all circumstances. I wrote, concerning transistors:
The lifespan of a transistor is essentially forever. The power rating for a transistor is a function of temperature and thus die size, color inside the lines and the device will never fail because it passed high current.
I did not, however, address LEDs, rectifiers, MOVs (which soon fail), etc. More on those in a bit.
If transistors really failed after a mere 11.4 years of solid use we'd damn well know about it. A crash plan would have been developed to replace those pesky and unreliable devices. Because planes would be falling out of the sky, medical devices would be failing, and phones would not work, etc.
Look at large-scale transistorized installations which run 24-7-365, such as the phone company, air traffic control system, military systems (including air force and navy), and, oh, the list goes on and on.
Utterly bogus expiration numbers are placed on products to evade lawsuits and make more money. Drugs and nutritional supplements are like the latter. Most never expire. (Aspirin, however, sort of does. The acetyl group cracks off in the presence of moisture to yield salicylic acid and acetic acid, i.e. vinegar. But it isn't clear that the tiny amount which has degraded is an issue; the salicylic acid is irritating to the stomach and causes greater bleeding. The human nose can detect vanishingly small amounts of acetic acid.)
Now, LEDs are a different matter. Over-driving a solid-state LED with excessive current or voltage increases light output but decreases lifespan. This is routinely done. Most LED bulbs fail after maybe ten thousand hours, well, the light reduces to 50% of nominal, because the junctions are overdriven (excessive voltage or current) to increase lumen output, poor thermal management increases the junction temperature (biggest part of an LED bulb is the heatsink), the packaging materials degrade, the seals are poor permitting the ingress of moisture, etc. Plus the ones which contain capacitors have those fail. Organic LEDs, such as those in OLED TVs, degrade from oxygen and moisture. This is why I have not yet upgraded to an OLED TV. Well, that and the cost is rapidly dropping.
I studied this when trying to understand LED ballasts for the tubes I used to replace my fluorescent plant lights. (I am growing tropicals, not weed, so no need to call the DEA on me.) The lumen output and lifespan vary with the ballast. I eventually opted for the 105% ballast to up the lumens / watt, as the bulb cost is quite low and will be even lower in another five years. The ballast for two bulbs cost twice as much as the bulbs.
The MOV which is solid state, being a metal oxide, fails because current paths through the device from voltage spikes create lower-resistance paths. Over time the resistance drops low enough to conduct at mains voltage, not merely excessive voltage.
Rectifiers which are run with excessive voltage or current also suffer junction damage, just like transistors will.
But properly manufactured transistors, i.e. not Chinese counterfeits, operated well inside the design specifications so the junction doesn't overheat? If those actually failed after 11.4 years, we would know about it.
