DQ10 Xover rebuild
kcarl
I have a pair of post 4134SN DQ10s that are in need of some work. The xovers are a mess, having a variety of caps from who knows where and very sloppy workmanship. I have a copy of the xover schematic and have put together a list of parts at Madisound. The woofer resistors look a bit dark, so I plan to replace them and maybe others. I've read that non-inductive metal film resistors are best for audio, but would it screw things up to use them in the DQ10? I'm assuming the existing wire-wound resistors in the 10s are non-inductive, but I'm not sure - anyone know? Any input on the subject would be greatly appreciated. I've had these for some time and would really like to get them cleaned up.
THanks,
Kcarl
Check with the Dahlquist group on Yahoo. You should find some information there.
cubdog
