This is a follow up from a previous thread. Turntable was working well, having been professionally cleaned, adjusted, lubricated etc. a few years ago. After some time of non-use, it did not work - the problem was that the idler wheel came very close to the motor spindle but did not contact it. The idler/pivot assembly was removed, taken apart, cleaned, and relubricated (nothing was dirty except the nylon washer that holds the wheel on). I did some careful "dressing" of the wheel but did not want to overdo that. With the turntable off, the idler wheel spins very freely; a bit less so with the nylon washer installed.
With the platter off, the idler wheel still does not contact the spindle, but it is so close that if I tilt the turntable up from the left side, it does and spins properly. With the platter on, the platter very slowly starts and then builds up some speed (have not tried to play a record, but I figure the slow start-up is not great for the rubber on the wheel). The part of the underneath of the platter that the idler wheel contacts is clean. There is nothing loose or funky about the motor spindle.
So - this is a matter of a very close tolerance not being quite right - it is not that the idler wheel cannot contact the spindle, it just doesn't quite (at least when the turntable is flat). Is this a case of needing to replace the idler wheel, or is there something more about the pivot that needs to be dealt with?
Thanks for any advice.
