Me Tarzan
EARTH
Considering updating HT system with a new pair of subs. Receiver has only one Sub Out and I know you can split signal and run 2 powered subs no problem. Question is: What are the pros and cons of installing line level in/out as dedicated left and right subs to go with the front mains? With the subwoofer output unused will the signal be processed differently? I would guess most movies are mixed with the sub in mono so that the signal would just be equal left and right if not using the sub out? And if not mono then would only benefit...?
Receiver is Onkyo TX-SR313 5.1 used 90% movies 10% music
Front mains are Tekton Mini Lores
Polk Center CSi A6
Rears are originally the Onkyo fronts
Subs considering a few options in the $2-400 each range...
Thanks, Ron
Polk Center CSi A6
Thanks, Ron
