It will stay on indefinitely with the rectifier tube. As soon as I put any tube in, the fuse pops. I have a quad of EL34's in my 8B, but I am afraid of damaging known good tubes to test.So it holds with just the rectifier but not any of the output tubes? I suppose they could all be bad but it seems unlikely. Try it with a dim bulb tester and monitor the voltage across the 10 ohm cathode resistors. Maybe try one tube at a time, and set the bias pots as negative as they will go. A bad tube should do something strange, either the voltage at the cathode will go high, or the bulb will get way too bright. Probably need 100w or so for this to work
I have not, advice?Have you checked the OTs? I had this issue recently, took forever to diagnose and found one of the OT leads was ‘repaired’ and hooked up to the wrong winding. Created tons of issues.
6CA7's installed one at a time, fuse pops shortly there after. No 12AU7's installed at any point, I can't get it to beyond about a minute of power up.By any tube other than the rectifier, do you mean even with just a driver tube installed, no power tubes?
Also, use a LBL and / or variac if you have either.6CA7's installed one at a time, fuse pops shortly there after. No 12AU7's installed at any point, I can't get it to beyond about a minute of power up.
Yep. Going to have to build a good one. I am pretty sure I have all the required items.You really should build a dim bulb tester. They're cheap and easy to build.
There must be a short somewhere if even just putting the driver tubes in will pop the fuse. There's a short somewhere.![]()
Late to the game, but here is the voltage chart from my vta st70 instructions.Is there a voltage chart in the assembly manual for this board?
