As I prepare install the Radio Daze glass, BTW it is EXACT. Great job RD!, worth the wait. While I have the unit out of it's case, plan on replacing the IIRC low testing 6SH6. Have a replacement now.
I'll go ahead and test all the tubes in the IF/RF section again. Problem being slow warm up time. 10-15 minutes for FM to work normally. Sluggish is an understatement. Then it's good and strong for deep fringe area I'm in.
Just wanting to know what could cause this. I'm thinking bad tube. All of the Telefunken 12AX7's passed the Gm. tests with flying colors.
Also found a NOS Amperex EM84 in my tube stash as my "A" is dimmer than dim. I'll look into the @analogaudioerc mod.
Haven't checked the PI adjustment, the pots haven't been touched. Probably should do that now.
With several more 7868 in my possession, will try to get a little closer there as well. I will say again, the 6.3 ct line bucker drops the temps on the output tubes. Highly recommend it, if you don't have one.
Since the rebuild this thing is jaw dropping with Klipshhorns
