Great tip! Thanks!In fact, if you wanted to "A-B" compare the "sound" of the 12AT7 to that of the 6AQ8, you could just get a pair of 6DT8, to contrast with the 6AQ8s. The 6DT8 IS the same tube as the 12AT7, just with a 6 volt heater (only) pin-out (same pin-out as the 6AQ8).
Regards,
Gordon.
The bigger problem you will likely have is not getting them to sound good in a circuit, but finding quiet ones. With such a large stash, I'm sure you will -- but they will likely be the exception rather than the rule. Like other RF based tubes, it is a frame grid tube, which is always prone to noise in audio circuits.
They were handed to you? Life is so unfair at times!
Dave
Dave
Yes, and this is the same difficulty that is had, by people using 6DJ8/6922 tubes, for the exact same reason.
It is possible to find quiet ones, but it's not always easy.
Regards,
Gordon.
Regards,
Gordon.
If I may chime in,
If actually had much better experience with these than an 12AT7..
They test better, last longer staying fresh, mostly even between sections.
And have not had noise issues, I Much prefer these over 12AT7's in audio.
Also they tend to come in the better "audio" brands as well, good euro tubes.
There also not a frame grid tube, basically there the same as a 12at7, just pins.
Jay -- Unlike a conventional 12AX7 -- where the grid wire is spiral wound around two secure posts, frame grid tubes use grid wire that is many times finer that that of a 12AX7, allowing the grid to get closer to the cathode -- which creates the rather large Gm figure that modern frame grid tubes have. But the wire is so fragile, that it must be built on a ladder frame for stability. The frame is adequate enough for stability with RF work, but the shifting on the ladder from heating, combined with the cathode formulation used that is not quite as stable, causes the tubes to generate more audio noise. From a theory standpoint, frame grid tubes have the capability of being the quietest audio tubes, as normal tube noise is a product of grid noise multiplied by the amplification factor of the tube. With such a small grid, the actual grid noise can theoretically be smaller than with conventional grids. Therefore, it's the practical matters of construction that get in the way of making quiet frame grid tubes.
Frame grid tubes were one of the last tubes to be developed. By the time anyone could get around to making them quiet for audio work, tubes were gone, and development work was abandoned. What a shame.
Dave
