EICO 667 Tube tester data sheet inaccuracies
bowtieman427
Hi all, Friend loaned me a EICO 667 tube tester he built. Read somewhere that the tude test data sheets are inaccurate for some tubes. Can anyone direct me where to get the correct information. I am currently testing 12AX7, 7868, and 7591. Tubes to be tested primarily audio vintage tube equipment and organs.
Thanks in advance
Jim
Go here:
http://www.antiqueradios.com/forums/viewforum.php?f=8&sid=ce40bd48c83a192cf0710789e9439602
The Test Equipment Discussions Forum at AntiqueRadios.com contains more information from experts than anyplace else I've ever found.
Do a search inside Test Equipment for "Eico and 667" (no quotes). I found 91 threads.
[Edit]: There are many different versions of roll charts for this tester. Some have mistakes, some newer versions corrected those mistakes, and contained newer mistakes. It can be a real challenge sometimes!
