Eico ST-70 Level (Volume) Pot?
byoungman1
Vacuum tube mafia kingpin
I'm starting a ST-70 refurb...the volume/level pot is toast. Any recommendations on where to source a proper replacement?
TIA
Alps makes some really nice two gang audio pots in 250K and 500k. You can usually find them on the bay. I don't think they have a loudness tap.
Thanks for the info. Are they a proper fit for this model?
Guess I need to read up on eliminating the loudness tap now...
Send me a photo along with the shaft length - from tip of shaft to where mounting collar meets the chassis. I could have the same pot or a replacement.
You just won't have any loudness compensation. No way to get around it. It would probably be better to look for a used component with the tap.
Finally got around to installing a new dual 100k pot (without loudness taps).
Do I just clip the wires that formerly went to the loudness taps, or do I need to reconfigure the wiring that went to the loudness switch?
