Finished first project!
oldgearhog
Since I have little time to work on this, it took forever but I finally finished a project that's been on my bench for way too long. I brought back to life a Nikko STA-2020, a little 10 wpc receiver. It seems to sound pretty good to me, but not as good as a little Pioneer SA-5200 in my other vintage system. It has a very basic tuner and not much in the way of features, just the usual BOTL buttons and knobs.
One channel was only playing a fuzzy low volume impression of real music while the other side worked fine. Mono sound ok, so I was puzzling over what was going on. No manual or schematic on line so I actually had to trace the circuit myself so see what was going on. That was a challenge by itself. Once that was done it was back to checking each output and input to isolate the problem. Also I am plagued by not having an oscilloscope that works. So finally, I narrowed it down to the preamp board and set about rebuilding it with all new caps and transistors. With that finished I was able to bring both channels back to their original glory!
I upgraded a number of caps using WIMA films where I could and Nichicon Golds for output coupling, putting larger ones in, and likewise for the main filter cap (only one, it's a single ended power supply) BTW, I had to increase the value and voltage quite a bit to get a cap big enough to fill the space where the old one was. Any thoughts on beating that problem?
And now with a good bath it looks like a mid-seventies receiver should and sounds not to bad to boot!
Nice! The filter cap issue, what I like to do is use some sort of foam to wedge between the new cap and the mount. Or I figure out how to mount it somewhere completely different.
Great job. I love the feeling of bringing back something from the dead.
Now you will be searching craigslist for parts receivers or ones with blown channels.
View attachment 1229259 View attachment 1229260
Winning = So Nice.
Fortune Favors The Brave
No need to search. I've got.a pile of.them to fix already. And I'm picking up one more on Tuesday. I keep telling myself to stop but I just cant.help myself. :banana:
