Fisher CC-3000 Pre
jerryd
tube junkie
I've been collecting, buying and selling vintage audio on and off for about 25 years... alot of it before it was vintage! I have one piece of gear that I have owned for many many years and to me, it's magic. It's a Fisher CC-3000 preamp that I've used with many different amps, and continue to use with a Carver TFM-6CB, and it never fails to impress me. Although from time to time, i have to shoot some cleaner in the controls, it's sound is not only better than any other pre amp I've owned... and I've owned quite a few...tubes included, but it's a considerable difference! I've done some searches but really can't find much info on this beauty. Does anyone here on AK own one, or have any info on this model?
From a FISHER catalog, specs only in german.
VORVERSTÄRKER CC-3000
Ausgangsspannung und –Impedanz 1000 mV/55 kOhm
Klirrfaktor (bei Nennausgangsspannung) 0,005%
Intermodulation (bei Nennausgangsspannung) 0,005%
Frequenzgang über alles
Phono RIAA±0,2 dB, AUX 20 Hz-20 kHz (+0/-0,5 dB)
Eingänge (Empfindlichkeiten und Impedanzen)
Phono MC 70µV/22 Ohm
Phono 1 2,5 mV/33 kOhm/47 kOhm/100 kOhm (umschaltbar)
Phono 2 2,5 mV/47 kOhm
Tuner 150 mV/100 kOhm
AUX 150 mV/100 kOhm
Tape 1, 2 150 mV/100 kOhm
Tape (DIN) 150 mV/330 kOhm
Höheneinsteller 10 kHz ±10 dB, Tiefeneinsteller 100 Hz ±10 dB
Loudness (bei -30 dB) 100 Hz/10 kHz +8 dB/+4 dB
Infraschall-Filter (15 Hz) -3 dB (12 dB/Oktave)
Ausgänge (Spannungen und Innenwiderstände)
Tape 1, 2 150 mV/22 kOhm
Tape (DIN) 4 mV (an 10 kOhm Abschluß)
Übersprechdämpfung Phono 60 dB, AUX 65 dB
Fremdspannungsabstand (DIN) bezogen auf Nennausgangsspannung
Phono (MM): 90 dB AUX: 100 dB
50 mW am Endverstärker Phono (MM): 90 dB AUX:100 dB
Netzanschluß 110/220 V, 50/60 Hz
Leistungsaufnahme 8 Watt
Abmessungen (B x H xT) 440 x 89 x 300 mm
Gewicht 5 kg
Michael-Otto
Another CC-3000
Picked up this pre from a friend, along with the other components (tuner, amp, cassette deck, EQ and system timer). Looks like it was an early rack system before they cheapened the line. I have a host of manuals and can scan them if anyone likes.
Hmm, From many years, I own full rack system of this Fishers components. CC3000, Tuner, EQ. Also amps, BA3000 and BA6000.
For me their look is the best. White aluminum.
About sound, what to say?
BA are mid level integrated amps. May be impressive for their time, late 70's.
Before a few months I bought this (damaged) BA6000 for donor, for my new project amp. Only I can say, is that, my new DIY amp, perform better than original BA3000. With driwers 2SA1837 / 2SC4793 , and 2SA1943/2SC5200 Toshiba.
I've got a CC-3000 pre amp about five years ago and I love the thing. It drives a X-101C and a Fisher 800B. I recapped it a couple of months ago.
Hope this helps:
PREAMPLIFIER CC-3000Output voltage and impedance 1000 mV/55 kOhmHarmonic distortion (voltage output) 0.005%Intermodulation (at nominal output voltage) 0.005%Frequency response about everything2 DB phono RIAA±0, AUX 20 Hz-20 kHz (+ 0 /-0, 5 dB)Inputs (sensitivity and impedance)Phono MC 70µV/22 ohmPhono 1 2.5 mV/33 kohms/47 kohms/100 kohms (switchable)Phono 2 2.5 mV/47 kOhmTuner 150 mV/100 kΩAUX 150 mV/100 kΩTape 1, 2 150 mV / 100 kohmsTape (DIN) 150 mV/330 kohmsHeight adjuster of 10 kHz ± 10 dB, depth adjuster 100 Hz ± 10 dBLoudness (to-30 dB) 100 Hz / 10 kHz + 8 dB / + 4 dBSubsonic filter (15 Hz)-3 dB (12 dB/octave)Outputs (voltage and internal resistance)Tape 1, 2 150 mV / 22 kohmsTape (DIN) 4 mV (degree kOhm at 10)Crosstalk attenuation phono 60 dB, AUX 65 dBSNR (DIN) based on nominal output voltagePhono (MM): 90 dB AUX: 100 dB50 mW to the power amplifier phono (MM): 90 dB AUX: 100 dBPower supply 110/220 V, 50/60 HzPower consumption 8 wDimensions (W x H xT) 440 x 89 x 300 mmWeight 5 kg
This might be easier to read...
PRE CC-3000
THD (at rated output) 0.005%
Intermodulation (at rated output) 0.005%
Frequency response over all
Phono RIAA ± 0.2 dB, 20 Hz-20 kHz AUX (+0 / -0.5 dB)
Inputs (sensitivities and impedances)
Phono MC Ohm 70μV/22
Phono 1 2.5 mV/33 kOhm/47 kOhm/100 ohms (switchable)
KOhms Phono 2 2.5 mV/47
AUX kOhm 150 mV/100
Tape 1, 2150 mV/100 kOhm
Tape (DIN) 150 kOhm mV/330
Height adjuster (Bass)10 kHz ± 10 dB, depth adjuster(Treble) 100 Hz ± 10 dB
Loudness (at -30 dB) 100 Hz/10 kHz +8 dB / +4 dB
Subsonic filter (15 Hz) -3 dB (12 dB / octave)
Outputs (voltages and internal resistances)
Tape 1, 2150 mV/22 kOhm
Tape (DIN) 4 mV (10 kOhm to completion)
Crosstalk Phono 60 dB, 65 dB AUX
Signal to noise ratio (DIN) relative to nominal output voltage
50 mW at the power amplifier phono (MM): 90 dB AUX: 100 dB
8 watt power consumption
Dimensions (W x H x D) 440 x 89 x 300 mm
Weight 5 kg
Hi TP static,
I have a similar possible setup with a Fisher 400 Receiver; just curious, did you rewire the 800B to get a pure pre-amp input, or are you just running the CC-3000 pre-amp into the AUX in on the 800B, effectively having two pre-amps? Cheers! -R
Very old thread, but it made me curious about the Fisher CC-3000. Found one for the right price. Holy crap! The OP was right. For the money, this is by far the best preamp I own. Just seems to do everything right. Currently feeding it to a McIntosh MC-2125. Yeah, bizarre combo, but Wow!
Very old thread, indeed and now even older. Earlier this year I connected a Fisher CC-3000 to a Carver M-400a amp, Harman Kardon TU-910 tuner and KLH Thirty Eight speakers (not considered exceptional speakers). Not sure, but I believe the TT was Technics SL-Q3. Quite a surprise for how great it sounded. Presence and lots of detail.
The room is 12 ft x 15 ft, two exterior brick walls, interior surfaces are real plaster and the floor is brick. I've wondered if these things make a difference. On the other hand, at my age much of my extended high frequency range hearing is gone. Some day maybe I'll have time to set up another system in the same room (and the CC-3000 setup in a different room) to test whether the room enhances the CC-3000.
Maybe I could be shot or hanged for writing this, but the CC-3000 gave my HK Citation eleven a run for its money, as they say, in this same setup.
This Fisher model is from 1979 to 1981, and made in Japan. Some have said it and the related components were the last good Fisher units.
Nice things about the CC-3000 are 3 phono hookups, three MM loading settings and MC.
I can understand the bizarre combo with the McIntosh.
My Fisher CC-3000 is still going! But I sold it to a neighbor, who pairs it with a NuForce STA-200 (Goldmund JOB 225) amplifier. The low gain of the Fisher preamp pairs very well with the high gain of the NuForce amp. Sounds great!
i've had a few across my bench. kept one for myself. been using it with a nad 2140 for a few years. pretty good phono stage.
the nylon switch couplers are the achilles heel of this unit.
just the cc3000
the ba3000 and ba6000 power amps are stk based. toroidal transformers. they are dull and flat sounding(even after recaps) i've had several across my bench and they are all boring sounding. the ba6000 shocked me with 170wpc @1khz @4 ohm before clipping. but who cares how much power it has if it sounds 'meh'
they look good with their analog vu meters but again, who cares if it sounds "meh"
the matching eq is ok but nothing special. i think i have one in the box somewhere. its a 10 band but the channels are combined on the sliders.
the tape decks look nice but i've not heard them. they all needed too much disassembly to change belts and i was too slammed to mess with them.
the tuner is a tuner
the turntable was overly complicated messes. i think they were programmable. i never had time to get intimate enough with the table that was here to get it working.
here is a gutshot of mine.
note the nylon couples. they were repaired and reinforced with steel mesh and a soldering iron.
heres a ba 6000
here is the table
guess i took no pics of the tape decks. i know i had at least one 3 head that matched. it had vu meters and it did look good....
