Other than the zero adjustment on the meter itself, it is the 390 Ohm resistor that calibrates the meter to the correct setting. However, that calibration is very hard on the output tubes. I recommend lowering it to 240 Ohms, which will then cause each tube to operate at a quiescent current of 35 ma when adjusted to the set line, assuming that the meter itself is operating properly.
Dave
