Hi Everyone!
Came upon this beast of an old Fisher 2 Channel AM FM Stereo Receiver 143.92541600. I believe there were sold at Sears? Built like a tank with the exception of the tuning gangs, which look like they belong in a transistor radio set!
Pre amp works fine, but the amp blew the outputs on one side. I am using the Fisher 301/401 power amp schematic as so far it seems to be the same power section? The outputs are Darlington M TR 01064-9 and 02064-9. The only subs that show up on the net are NET 247 and 248, I think I can cross reference these but would also welcome suggestions for the output replacements.
The sub that I can't find is what Fisher calls the "idle regulator transistor" and the schematic refers to it as TR 0 10565, Q 803 and 804. They are tied between bases of the outputs on each side.
Any help would be appreciated! I may also need help with other transistor subs back in the chain, which I haven't tested yet. such as Q 807 809, which are labeled TR 01063 and 02063. needless to say the DC output is high, even without the outputs in line. Thanks!
