phickman
Member
I'm working on a Fisher X-100-3 this unit has a strange circuit topology..
here is what happened an associate brought it in to me and complained that it was playing fine and it suddenly stopped in mid playing and he said he smelled someting burning so powered it off right away. On my bench I tested all the tubes, this one has the 7189 outputs..next bringing it up on a variac slowly nothing strange, all tubes light fine except the 12Ax7's V-1, 2, 3 these are the ones that have the strange fillament connections they go to the cathodes of the 7189's.. from what I can find in my research.. their should be about 30-40 vdc on the cathodes this is part of the topology that gets the v1,2,3, filliaments lit with DC.. I can only get about 1.4 volts..they are stone cold and no music is passing, I can directly injet sound at the 12AX7 phase splitters and get plenty of volume..as they have direct a/c from the transformer as the 7189's do. I have replaced the electrolytic in the Cathode circuit and tested the resistors and also cleaned all the tube pins and sockets.. still nothing. oh and the power supply B+ seems good at all critical areas
ok you Fisher pro's help me here.. I do not have a schematic as it is so rare
what can you tell me to check for
