I used to have this problem with my Sherwood and it ended up not being the amp at all--one channel would be much lower until I reached a certain volume and it would even out. One of my speaker cables turned out to have a bad solder joint where the spade lug had been soldered to the cable. It was hidden under shrink tubing. One day I bumped the cable and the sound started cutting in and out. If I had played around with swapping cables I might have figured it out much earlier. Anyway, once I resoldered the spade lug to the cable, the channels were even throughout the range of the volume control, and remain so today.
So maybe this isn't the problem you have, but it might mean that your problem isn't contained within the amp at all. Or it might mean that all of your components are checking OK on value and that there's a bad joint somewhere. Did you check operating voltages against a schematic?
