petehall347
the brandy coffee man
any chance of some good pictures so we can see if anything looks obvious ?
I'm not sure how to describe the power switch. It's one of those buttons that you press but comes back to place. It's unlike the buttons on vintage receivers, which you press and then stay depressed. Does this make sense?When you plugged it in after replacing the fuse, the power switch was in the off position?
I will definitely look into that when I have more time.Could be shorted output transistors, may be worth removing them then trying again. Would definitely build a dim bulb tester it's cheap and easy and can limit the damage done each time you try a new fuse. This seems like a cheap way to learn a few repair skills a s the value of the receiver is low and there is not much at stake.
