Tom Bombadil
AK Member
Picked up a pair of these on the used market for well under their $1500/pr list price. I have a low powered (5 wpc) tube amp and was interested to see how they might pair up. The 906 is a pretty easy speaker to drive for a bookshelf, spec'ed at 89.5dB sensitivity and 8 ohms.
The 906 is part of the Focal Aria series which fits between their less expensive Chorus line and their Electra line. They developed a new midrange driver, which sandwiches flax, yes flax, between plastic layers. Have never seen this before. Visually it's very attractive.
I tested out that sensitivity and it seemed to hold out. I own two older speakers which were measured at 85dB. Set my preamp's volume control at the same spot, running into the same amp, and measured the volume levels at my listening position. The 906 measured out a consistent 5dB louder.
Paired with the lower powered tube amp, the 906 sounded pretty good but lacked the emotional impact which I desire from a monitor speaker. Nice midrange, delicate highs, warm'ish mid to lower bass but less definition on string bass. The soundstage was not as wide & depth as described in some of the professional reviews of this speaker.
Then I connected to my old trusty Cary SLA-30 amp, a 30 wpc EL84-based amp. And I was immediately blown away. To the point of having to switch the amps back and forth a couple more times to verify what I perceived was real. Big soundstage with great separation, and better yet, fabulous vocals. I ran through CDs from Holly Cole, Norah Jones, Diana Krall, and Steve Earle and it was a treat. So natural. Highs were nicely presented, good detail but not harsh. The midbass was smooth with better definition. Still a bit warm but a nice overall balance. I have big floorstanding speakers which are very neutral and go very deep, the 906's bass is much different but in a way which I appreciated from a smaller speaker. Deep notes just aren't there, but the bit of warmth makes for a very seductive sound (listening to Norah Jones as I write this, and it's nice!).
With the higher powered (but still a fairly low powered) amp the piano notes have more weight, as does the string bass. Vocals are lush with space around them.
I've listened to several more expensive Sonus Faber monitors over the years and have always loved their signature sound. The 906 takes me a good part of the way there. They draw you into the music.
I have no idea how they sound new out of the box or how long it takes to break them in, as these were purchased used. Not sure they would be my choice if rock or hip-hop were my primary music interests. They are okay on rock (don't have any hip-hop to test) but I might like something with a more aggressive mid-range and deeper bass. They certainly are very good on CSNY, Jackson Browne, Fleetwood Mac and that genre.
Here are links to three reviews, all quite positive.
The Absolute Sound
http://www.theabsolutesound.com/articles/focal-aria-906-compact-loudspeaker/?page=2
Soundstage
http://www.soundstagehifi.com/index.php/equipment-reviews/768-focal-aria-906-loudspeakers
Quote from Soundstage:
"The Aria 906 is packed with Focal’s latest driver technology, and the results are fantastic. I was smitten by the Arias’ huge soundstage, neutral midrange, and beautifully rendered highs. This bookshelf punches above its weight, and compares favorably with other well-regarded speakers, even above its price range. But the Aria 906 is greater than the sum of its parts -- it was simply a wonderful speaker when I just wanted to relax and listen to some music."
AVforums
https://www.avforums.com/review/focal-aria-906-loudspeaker-review.9570
A quote from the AFforums review:
"The 906 also manages to distract from this because it does have a joy factor that I’ve not really experienced with a Focal speaker before. Beyond the accuracy and control, there is a sense of life and excitement to the performance that makes the 906 a very easy speaker to listen to long term.
What moves the 906 from worthy to genuinely covetable is the new found sense of excitement and joy it seems to have across a huge range of material. Unlike on previous occasions, I don’t simply admire the 906, I genuinely love it and for this reason, Focal’s latest speaker comes highly recommended."
Equipment used in my evaluation - my "second" system: Cary SLA-30 amp, Inspire SE EL84 amp, Dynaco PAS-4 (mid-90s 6DJ8-based preamp), Conrad Johnson PV10A preamp, Sony SACD player, Parasound D/AC-1100HD dac.
The Absolute Sound
Soundstage
AVforums
