I went from a Terry DeWick serviced C33 to a c50. the c33 is one of the greatest vintage pre amps ever made, my C50 is MUCH better than it was, no contest. it is MUCH quieter than the c33, no contest. the remote is a big help, but even without it, switch. I too thought the whole firmware based thing was bad, you get over that quick after hearing it. I have no experience with the MP 100, but I have found as the macs get newer the sound improves. I loved my c33 one of the longest owned pieces of audio equipment I have ever had, but I couldn't go back. the worst a c53 could be is just as good as the c50, and it has a better dac than the c50 will have in it.
Side note the dac that is in my MCD 1100 is newer by one click than the one thats in the c50, so my MCD 1100 sounds better than the DAC in the c50 ( same DAC as the C52) so the c 53 is probably better still. I think it has the DA2 module, so it will be up-gradable when the next leap forward is happening and you won't even have to replace the c53 for the most likely reason you might have had to, the only thing I really don't like about the c50 now is you can't upgrade the dac, like a C53.
it will be a very noticeable, youre c33 is holding back that MC 205 you have.
