Thanks, I thought they looked pretty small.25v. i used whatever i had at hand- over sized and over voltaged. sound has improved significantly to my ears- wider stereo effect and mids. mids seem a bit over emphasized, though. this is just an experiment for me; a toy. have about 10 "real" pre-amps.
Many moons ago, I started a list of tubes and opamps that had been mentioned as working with the Tube 03. The tubes would be able to used in the Tube 01 and 01J also, but those units have no tone controls so no opamps. The 03 will work, evidently without opamps. I prefer the tone controls, so I've never tried the unit without the opamps. I have my list somewhere. but in the meantime, a search of "opamps," in just this thread, will yield all kinds of references to models. Some are still available at digikey and mouser and you could get lucky with thebay, but beware, you may get a counterfeit parts. I have a couple pairs of the MUSES8920 that I could be talked into parting with as I switched them out for an inexpensive pair I found on ebay. The numbers escape me, but I mentioned them here relatively recently. NZVinylFan has several pages of tubes he has used so his posts are noteworthy. The thread is a treasure trove of info. Good luck. If I come across the list I began making, I'll post it, but don't hold your breath. lol
Edit - the power supplies are available on Amazon. Not sure if that's an option where you are.
I don't know about the specs but supposedly one of the op amps runs the tone controls - I think it may be a dual opamp - and other one runs the volume control. So it makes sense that the control responds differently after an opamp swap. Some people have removed them and this defeats their function but the preamp section still works. So it seems like it functionally converts the -03 into an -01.Tech question about Tube-03 ... does anyone have the tone control specs ?? Just curious what the frequencies are and db +/- ... the high freqs really seem to improve with a slight adjustment ... I have installed improved op-amps, (I can't recall which ones I finally decided on .) and not sure if these affect the tone controls ... it still sounds great ...
They are essentially the same op amp.I I also want to try the LME49720's and a pair I have yet to hear, the LM4562's, in the same fashion.
You might want to try some of the discrete FET plug in options from Burson and Sparkos. I'm quite happy with Burson V5s in a Music Hall 25.3 DAC.
I look at it as a comparatively cheap way to truly elevate the performance.I would love to try the Bursons and Sparkos and some others, but when the cost for one of those opamps is double the cost of the unit itself, it almost makes a mockery of the thread itself - $31 Wonder.
It just attenuates (reduces) the incoming signal by 6 db. Unless you have your volume control turned up all the way, you're also reducing the level of the incoming signal.The new one has a switch that says - 6 db? Please help me understand why you would want negative gain?
Sure, tube amps are typically a better impedance match for these than SS or Class D amps.A lot of this is over my head. I have a 6L6gc SET 10 W tube amp coming. Do you think this FX pre would work?
I thought it might be a Chinese amp but I've never seen one that uses 6L6GCs. I'm sure the one you're buying will be much better since the Chinese amps (the more modestly priced ones, anyway) require some mods for reliable operation.No volume pot. PJL Electronics, the guy on the bay is making me one. He is really great to work with. I have ,among other items, his Retro phono preamp.
Is that a man poking the Badger? LOL!
