So your output coupling caps are now a combination of film and PIO.I have put 2 pio (K40Y-9) in bypass under the card and i can closed te fx box after.After 2 hours of burning it became better sound... Let's turn and listen
I have understand we can bypass the cathode also someone try or can explain?
I believe it’s the 12 volts that matter.Can I substitute this? 5 amp for the 3 am PS 3kx?
Yes, but the higher amperage rating won't offer any benefits.Can I substitute this? 5 amp for the 3 am PS 3kx?
Exactly. The amperage rating of a power supply just means that it's capable of supplying that much current but it's the device that's connected to it that determines how much is actually drawn.I believe it’s the 12 volts that matter.
Besides the higher gain, which is definitely not needed, the other effect of adding a cathode bypass cap will be higher distortion.No problem about that! i work and Iisten fx 03 (alsoFX01)) and i can reduc the gain i know "my"sound"system"
I just want the better and clean sound
You're correct, those are 1uf 63v film caps that are used as coupling caps. In the schematic I posted above they are shown as C10 and C12.Well I'm getting bleary eyed trying to find this answer, but I have to admit defeat as I've been thru many pages. Can anyone tell me the values of the two caps I have identified in the photo? I believe I can make out- 1 u J63 -but that's the best I can do. Don't want to guess this means 1uf/63V. Recommendations? And what function do they have in the circuit? I'm ready to update both my 01 and 03, photo is of the Tube 03. Ordering different op amps and caps to give it a go. Thanks in advance for helping the old guy.View attachment 2773739
Well, I don't own an FX so I may be mistaken. There are two other 1uf caps used on the input to block any DC that might be coming from the output of a source component. Unfortunately, they put them in the wrong place, as I've explained previously.FlaCharlie- Thank you. But if those small 1uf/63V box caps are C10/C12, then where are the (4) 1uf/250V larger box caps in the circuit? At this 250vdc voltage they wouldn't be on the input would they?
I've been pokin around here since '20 when I got a tube03. Tubes have been rolled(Voshkods now), ready to tackle op-amps.https://www.head-fi.org/threads/opa...-muses8820-and-8920-burson-v6-classic.870832/
Here's that article I posted awhile back on a bunch of opamps that a guy test drove. These were not tested in a Tube 03. I just used the info as a reference. The only thing I have no way of proving is whether the opamp627's I have are real or not. There is some discussion on page 112 of this thread that basically designates the opa627 from ebay to be fake, but this was a couple years ago. I'm almost certain the ones from the Philippines were not available back then because when I looked originally about a year ago they were no results on dual 627's. Either way, as Rob43 suggests, just give them a go for the $10/pair and decide for your self. There is a high likelihood that they are fake, but they sound great nevertheless.
Oh, didn't know about the Burr Brown. A couple of days ago I ordered the OPA 2134PA from Mouser, but they're Texas Instrument. Is there likely to be a difference between the two? Are there any other makers of this op amp, thought the number was proprietary to the manufacturer? New to solid state gear, been fooling with vacuum tube stuff for years.I've been pokin around here since '20 when I got a tube03. Tubes have been rolled(Voshkods now), ready to tackle op-amps.
Ordered a set of BurrBrown OPA2134PAs from Amazon, $20 for a set. Wow, what a change. Now, I have a new op-amp rabbit hole to go down!
Pike
Pike
I'm curious what you mean by de-rating the resistor. Are you talking about the 100k resistor going to ground from the output jack?Today i test derating resistor on output!
