billyz
So each speaker is 7.5 ohms. If you run two sets , they are parallel so the impedance is now 3.75 ohms ! if you then parallel a 8 ohm resistor your total impedance load will be 2.5 ohms ! you will likely damage your amplifier if it does not shut off in protection. Also, these are the static impedance numbers , the actual impedance is probably much lower at the lower frequencies. Your amp is rated for 65w at 8 ohms. You are trying to drive too low of an impedance.
You can get away with it at lower volume levels. Also, we do not know the health of your Receiver ? Has it been rebuilt, recapped, and biased ?
