Hi everyone! First (real) post here so I hope I'm not violating any rules. Desperately looking for some troubleshooting advice on my HK730.
Bought a -730 from one of the auction sites. Cosmetically very good. Seller said it had some static but wasn't tested or played much, bla bla. I was hoping that some deox in the pots and switches would fix if it was an issue. That's about the extent of my current electronics troubleshooting skills.
Played great for the first 20 - 25 minutes or so before loud, obnoxious static from left channel. Out to the bench and plugged into the DBT. Same issue right at power on. Time to order some parts! Thanks to Dlucy and the rest of this community I was able to navigate subs for originals, etc. After checking the outputs using both the DMM and the $30 transistor tester, all seemed good to go. Replaced both the mica shims and silicone thermal compound for the output transistors then rebuilt the left side only (for testing) of the power amp at this time. Rebuild here is new caps and transistors. Sounds pretty good...except now the right channel is dead
1) Checked all fuses - all good and to original specs per service manual. 2) Same issue with FM, CD via Aux, all switches and pots wiggled, jiggled, in, out, etc. No help (and no static or other snaps and crackles).
3) Check power amp idle per service manual - Left side set at 35mv with new VR. Right side = 0!
4) Rebuilt the right side of the board.
5) Still same issue. Drats!
6) Started checking voltages at board transistors using the 'Transistor Elements Volt Chart' found on pg-23 of the SM. Results in the attached table.
Any help would be greatly appreciated! Have spent hours now reading some excellent posts that I thought might be relevant and have tried and tested things accordingly with no luck yet. Was hoping to I.D. the issue before moving onto the rectifier & sub-rectifier boards as I have the caps and transistor for them.
