He cd301
Tdi434
Hey guys! I'm new to the forum fairly new to vintage audio a little hobby my dad and I picked up. We purchased a hK cd301 tape deck that was not working I got it going. Then the little roller belt broke off the one that allows cassette to rewind and fast forward. I cant seem to find any parts. Any recommendations on where I can find that part. Thanks in advance
What country are you in? It will keep us from making poor suggestions.
I am from the USA. After doing some more research what I'm looking for is the idler tire its still intact but shows signs of cracks but what I really need is the tire that goes on the motor pully
You should to HiFi Engine and see if you can download the service manual for your deck. That will help. Vintagelectronics.net is a good source for belts. they may have idler tire as well. Bob is the owner. I have used O rings as replacement for idler tires from time to time. They work fine for me. McMaster Carr is a good source for these. They have round and square profile O rings.
T
Thank you. I found a latex hose at my local hardware store that was the same thickness and diameter and I cut it to size and it's working great now thanks for the source I will definitely check them out for my other stuff I am now working on a hk 3500 tape deck it plays but fwd and rwd do not work the mechanism is not moving properly....
