Hi every one. Thanks for letting me in. I'm trying to save some bruises and would like to find out if I'm on the right track. I've read a lot of post on AK and feel the best knowledge is here for this project but I'm getting confused. I'm knowledgeable to the point of being dangerous. I've recapped a few stereos and worked as an electronic tech on fuel system 15 years. Mostly swapping boards. I'm capable with finish carpentry
I've recently acquired an in progress project. Unfortunately the gentleman passed away before he could complete it. May he rest in peace.
I'm not afraid of diving into this but, I'm not sure what to do with the cabinets and crossovers. The front and rear baffles are solid wood and the cutouts look like he used a chain saw and need replaced. I'm thinking 3/4" HDF particle board front and rear.
Components:
Woofers are Heathkit 401 149
Drivers Heathkit 401 150
Horns H 811B
Crossover Is Heasthkit AS101
Cabinets are huge, solid walnut? 24Wx36Hx18.5D Model17???(A guess)
My understanding:
Woofers are Altec 416-8A Very Good
Drivers are Altec 806-8A Very good
Crossover is proprietary ok but could be better.
Cabinets should produce some nice sound if done correctly.
My questions are primarily on the cabinets and crossovers.
Do the cabinets need to be tuned?
Is 25Hz correct for the woofer?
What kind of vent is required?
I've read the crossovers are based on the speaker components and not the cabinets. Is this true?
I've also read that there is an improved model 19 crossover plan somewhere that would be ideal. Is this true
Thank You for any help.
Components:
Horns H 811B
My understanding:
