hello can someone direct me to a tube chart online ?
Redcatcher199th
FREEDOM Isnt FREE TYVETS
I have 300 + tubes but dont know jack about the cross over or the value
also I have a tester without a manual and would like to learn how to test tubes thanks in advance
tube tester is a Seco model 107 ? is it ok for testing ? how or where to take it to get it calibrated or does it need to be hopefully this link will
work :S
Brian
Redcatcher199th, I can't help you with your tube tester, but I can assist you in posting:
When you hit ‘Post Reply’, look beneath the text box, for the 'Manage Attachments' button. When you hit that, a window opens, that you can use to browse to the image you want to upload to AK. When the ‘Choose File’ window opens, you select the image, click on ‘Open’, and the path will appear in the box beside the ‘Browse’ button. When you are finished selecting images, up to 5 in number, click on the 'Upload' button, and the picture file(s) will be uploaded to AK’s server. All your upload files should appear in the bottom of the box, before you close the ‘Manage Attachments’ window. When you are finished typing, submit your message. Your picture(s) should appear in the body of your message. With respect to image size, the 'Manage Attachments' window will tell you, at the top of the window, after you attempt to upload, if you have exceeded image size or file size, for AK's server. 900x900 pixels, and about 150 KB, IIRC. You can attach up to 5 pics, and they will appear as thumbnails. This is good for pictures hosted on AK.
If you host your pics elsewhere, you can just hotlink with the 'Insert Hyperlink' button, multiple times above. The disadvantage to that is, if you remove the pics/changes hosts, the pics will be lost to AK.
Hope this helps.
Thanks for the links and the help on posting pictures I sure do appreciate it alot thanks
bolly,luvvinviny & dogscanskate I do appreciate the help ^:)^
thanks i am glad I finally signed up to AK :smoke:
Brian
Wooooooooooooooooooo Hooooooooooooooooo I just seen the window down below lol
Big Red Truck :scratch2: damn I have a hard head must be the German in me lol
Brian
