Christa
HI All- I'm coming to you guys for help again. I'm on the home stretch with this SX-727, but I am a little confused about this capacitor that I just pulled. Its a blue sanyo cap and the markings say 1/25. Its really hard to almost impossible for me to read the foil side layout from the service manual, so I've been pulling each pair of caps and being careful about double checking the values. This pair I believe are C27 & C28 - but I could be wrong. I guess it is a 1uF / 25 volt cap, but there aren't any 1 uF caps listed in the service manual.
Should I replace those with 2.2 uF caps - that is what I ordered based on the BOM or put a new order in for 1 uF caps?
I attached a picture - I still have one on the board - the other I've already removed.
Here's the BOM I used:
AF Board (AWK-010)
AWK-010: C7: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWK-010: C8: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWK-010: C13: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWK-010: C14: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWK-010: C15: 47uF 6.8v CEA: 647-UPW1C470MDD 47uF 16v
AWK-010: C16: 47uF 6.8v CEA: 647-UPW1C470MDD 47uF 16v
AWK-010: C21: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWK-010: C22: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWK-010: C27: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWK-010: C28: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWK-010: C29: 100uF 6.8v CEA: 647-UPW1C101MED 100uF 16v
AWK-010: C30: 100uF 6.8v CEA: 647-UPW1C101MED 100uF 16v
AWK-010: C31: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWK-010: C32: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
Thank you in advance for the help - I'm stuck here!
AF Board (AWK-010)
