Help me ID these speakers!
bangsezmax
Turntable Whisperer
I got these as a pull from a Fisher console, I think from the late '60s (not sure). Very cool, with two directional tweeters mounted over the woofers. No brand ID on them at all. The label on the bell says "Made in Western Germany".
So what the heck are they?
You got some great drivers there. I tried to buy a pair on that auction site a while back, but missed out.
I'm drawing a blank on the name though at the moment. It will come to me.
Hey it came to me, I'm thinking Lorenz LP 312 coaxial.
http://www.german-vintage-loudspeakers.com/navid.108/lorenz-lp-312-coaxial-speaker-30-cm.htm
Excellent!
Actually, I think mine are the version 2 -- http://www.german-vintage-loudspeak...nz-lp-312-coaxial-speaker-30-cm-version-2.htm
So with drivers like these, what would be the recommendations for a cabinet? Probabaly wouldn't need anything big. Ported?
Most of these old drivers need big cabinets, but OB may be a good option.
See if you can get your hands on an empty Bozak cabinet. They used very similar drivers in infinite baffle cabinets - they (the Bozaks) are very large, however. Those are some really cool speakers. I am tempted to use something like that (if I can ever find any) as a ceiling mount for the fronts on a home theater. The ceiling would act as the perfect infinite baffle. I wonder how the selectable impedance works - are extra voice coil windings available, kind of like a multitap transformer?
OB : Open Back?
Good option in evening wear. Never seems to go out of style... :thmbsp:
Cool! Sounds simple.
How large is "large"? I'm guessing you want something big enough to prevent bleed from the back to get into the imaging . . .
Your close, its more to keep the back wave from canceling out the front wave and removing all bass response. I'm sure there are parameters to OB, i do not have them. The bigger the board the better bass response. You also want to slightly offset the hole from center.
Search the web for "open baffle speaker design" or the such, gobs of info out there.
http://members.myactv.net/~je2a3/open.htm
This kind of design seems to work well (that little board center top seems to be important on many designs)...
